will not start but tries
34,732 MILES • 5.7L • V8 • RWD • AUTOMATIC
HDORAN
newly rebuilt engine tries to start but will not. it is getting fuel and spark. it has a carburetor and has an HEI distributor. if I use starting fluid I get a small amount of black smoke from the exhaust.
I thought I should add, it has a high rise intake as well as a knock off Holley carburetor unsure of size it is either a 600 or 650. it has flat top pistons, the original 64cc heads, factory cam, roller rockers that are 1.6. engine has ran with the original TPI setup but not good. I pulled the TPI to replace the factory injectors and broke the fuel rail so this is why I went non computerized.
Jan 8, 2017 at 4:50 AM
JOHNNY G.JR
  • 320 POSTS
Black smoke usually too much fuel. Is base timing correct?
Aug 17, 2019 at 9:59 AM
CJ MEDEVAC
  • 11,000 POSTS
Are you 100% sure the distributor is in correctly?
Firing order correct and is in sync with rotor direction?
If so, have you scooted/tweaked it a little one way or another to aid in better timing to start it up (until you can get idle speed and a timing light on it)?
The Medic
HDORAN
Yes, I have checked timing over and over again and it is right on. It just will not start. I just went and bought a brand new carburetor and no difference.
CJ MEDEVAC
  • 11,000 POSTS
What is the voltage at the positive coil wire with the key on?
The Medic
Aug 17, 2019 at 10:00 AM
HDORAN
My digital voltmeter is not working but my old one shows twelve volts.
CJ MEDEVAC
  • 11,000 POSTS
I know you have checked, maybe something got missed!
I'm sending "DAVID AND CHAD" to give you a hand!
CLASS 1
http://www.youtube.com/watch?v=5a2X9mSSlQY
CLASS 2
http://www.youtube.com/watch?NR=1&v=FHX1yXVyIMg&feature=endscreen
WATCH THESE A FEW TIMES, THEY ARE VERY HELPFUL
Can you send a pic of your distributor?
The Medic
  • 55,732 POSTS
Hey HDORAN,
Try moving the distributor a little bit counterclockwise.
Please let us know happens so it will help others.
Best, Ken
HDORAN
I have turned the distributor both ways tried 180 degrees, and 1 tooth each direction, I think I might have figured it out, it seems that the intake manifold maybe not sealing it is the one cheap thing I bought, I will post back soon and let you guys know
  • 55,732 POSTS
Okay sound good, have a good weekend.
Best, Ken
