Crank no start issue?
202,023 MILES • 4.0L • V6 • 2WD • AUTOMATIC
BRANDON234
Replaced cam shaft sensor and coil packs as well as plugs and wires... But now it doesn't start but gets power... it ran and drove great prior to this problem.
Jul 4, 2023 at 9:41 AM
  • 110,248 POSTS
Did this happen just since the repairs you mentioned? Let me know.
Next, in most cases a crank no start condition is caused by either a loss of ignition spark or fuel.
Here is what I need you to try:
See if it starts with starting fluid. If it starts and then stalls, we know it is a fuel-related issue. If there is no change, we need to check if there is spark at the plugs.
https://www.2carpros.com/articles/how-to-check-for-ignition-spark
Try that and let me know what you find.
Jul 4, 2023 at 4:14 PM
