Won't start and 'security' lite blinks
220,000 MILES • 2.0L • 4 CYL • FWD • AUTOMATIC
GENE29
Occasionally my Alero does not start and the security light blinks. I know about the 10 minute wait until the light goes out. I have been told that it needs a new ignition because the single key I have is worn. The problem is I don't want to spend 400 plus on a car with 220k on it. My question is: Is there anything I can do or have done that would take the 'security' thing out of the equation?
I spoke to a fellow that did something to his Cavalier involving a couple of wires in the ignition that solved the problem but his security light nows stays on. I would not care about that as long is it would start.
Thanks in advance.
Dec 26, 2014 at 9:56 AM
SATURNTECH9
  • 30,869 POSTS
We dont give out information on how to bypass security systems because it could fall into the wrong hands.You could have a bad pass lock sensor in the ignition cylinder assembly. Would have to read the codes in the computer and go from there.You could replace the ignition cylinder yourself and save a lot of money that way.you could get a ignition cylinder for about 108 plus shipping possibly cheaper on ebay.
Dec 26, 2014 at 2:48 PM
