Will not start after really cold temperatures
189,000 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
AK.BOOTY.907
Battery is charged, and it has a multiple cylinder misfire.
Dec 31, 2019 at 3:52 AM
Good afternoon,
Is the engine cranking normally and not real slow?
Can you hear the fuel pump run with the key on?
when was the oil changed?
Dec 31, 2019 at 4:05 AM
AK.BOOTY.907
It starts out cranking normally but then starts getting slow and yes to fuel pump and it's been a bit since last oil change.
Dec 31, 2019 at 4:28 AM
Okay, I would replace the battery. It should not go slow until about 10 minutes of cranking.
I would also change the oil and filter. That will make the engine turn easier.
Dec 31, 2019 at 5:20 AM
