Will not start after overheating?
124,000 MILES • 1.4L • 4 CYL • TURBO • 2WD • AUTOMATIC
BOB HILLS
Hey there, the wife drove the car and it overheated. We found out the water outlet was bad. After replacing it now the motor turns over but won't start? It doesn't sound like it's firing.
May 2, 2023 at 4:28 AM
  • 55,746 POSTS
Can you make a short video of the engine cranking over so I can hear it? You may have lost compression and I can tell by a video. In the meantime, let's do a compression test if you don't what to send a video.
This guide can help:
and
https://www.2carpros.com/articles/the-reasons-for-low-compression
And this guide can help as well:
https://www.2carpros.com/articles/car-not-running-advanced
Please go over these guides and report back.
May 2, 2023 at 9:43 AM
BOB HILLS
Hello Ken, I took a video for you. Also, it's getting gas. I checked the bleeder valve. It seems like it's electrical. Not getting fire. I appreciate your help and look forward to your reply. Attached is the video.
May 3, 2023 at 1:54 AM
BOB HILLS
When I have a helper I'm going to check the relays in the fuse box.
May 3, 2023 at 2:08 AM
  • 55,746 POSTS
Yep, there is no need to check the fuses or relays, that engine is no good. Thanks for the video, it helps. You will need a used/rebuilt engine, sorry about that.
May 3, 2023 at 7:25 AM
