Will not start after failed attempt to add new remote?
215,000 MILES • 1.9L • 4 CYL • 2WD • AUTOMATIC
JEREMIAH SATURN
I tried to add a new remote and followed the steps for programming. Now neither remote work and the lights on the dash illuminate but the car will not crank.
Apr 20, 2024 at 11:48 AM
  • 55,709 POSTS
It sounds like the car battery might be dead. Is the security light flashing? Here are the instructions of programming the key fob:
https://www.2carpros.com/articles/how-to-re-program-a-key-remote-fob
You can try a hard system reboot which works well,
https://www.2carpros.com/articles/step-by-step-guide-performing-a-hard-system-reboot-for-your-vehicles-electronics-systems
Programming
Each transmitter is coded to prevent another transmitter from activating the RKE functions on another Saturn, as long as that particular transmitter has not been specifically programmed to that Saturn.
A transmitter can be programmed to as many different Saturns as a customer owns, as long as they have the power door lock option. Each Saturn can be programmed with up to four transmitters.
IMPORTANT: If a customer needs to obtain more transmitters, or replacement transmitters, make sure the customer is instructed to bring all their Saturn transmitters for programming. The remaining transmitters must be reprogrammed. Once the new transmitters are programmed to a particular Saturn, any lost transmitters will not unlock the Saturn.
To program the Remote Keyless Entry (RKE) module with a new transmitter, use the following instructions:
1. Have all the transmitters that will be programmed to the Saturn present, even if only one is new. Put your key in the ignition, and keep it in the OFF position.
2. Locate the Data Link Connector (DLC). It is fastened to bottom of the left side of the trim panel under the steering column.
. Use a jumper wire to provide a path from the remote keyless entry System program circuit (cavity 8) to ground (cavity 4).
Use an available Saturn lead kit and splice. to create a jumper wire as shown.
Grounding the program circuit causes the horn chirp. Count the number of horn chirps. The number of chirps wilt correspond to the mode the RKE module is in.
4. Obtain the desired mode number by referring to the Saturn Security System mode chart.
Cycle the ignition key the number of times that correspond to the desired mode.
5. Keeping the program circuit grounded, simultaneously press and hold the LOCK and UNLOCK buttons on the transmitter.
The horn will chirp the number of times corresponding to the mode programmed when the process is completed (may take up to 15 seconds). If there is no response, repeat this step, making sure both buttons are pressed down firmly. If there is still no response, check the transmitter battery and battery contacts. If you are only programming the remote keyless entry (RKE) module with one transmitter, proceed to step 7.
6. Still keeping the program circuit grounded, repeat step 5 with the next transmitter. You must not allow more than one minute between programming the transmitters, or the remote keyless entry (RKE) module will exit programming mode and you will have to start over.
If you accidentally disconnect the ground wire from the data link connector (DLC) before completing this step, you will have to start over at step 3. If you accidentally disconnect the ground wire from the data link connector (DLC), after completing this step, only the first transmitter will be matched. If you make a mistake, start over at step 3.
7. Remove the jumper wire.
8. Test the operation of each transmitter with the Saturn.
9. Close the decklid or liftgate.
Check out the images (below). Please upload pictures or videos in your response to the problem so we can see what's going on.
Apr 21, 2024 at 5:24 AM
JEREMIAH SATURN
Thank you for your response. My son traced the problem to a blown fuse (on the body circuit) and was able to get the remote programmed and the car started.
Apr 21, 2024 at 11:00 AM
  • 55,709 POSTS
Glad you could get it fixed, thanks for letting us know. Please use 2CarPros anytime we are here to help.
Apr 22, 2024 at 3:10 AM
