Will not start after replacing both the accessory and drive belts
257,186 MILES • 3.3L • 6 CYL • 4WD • MANUAL
JESSBEEWRENCHIN
  • 6 POSTS
Truck won't start after changing/inspecting both the accessory and drive belts. Timing belt was not messed with for this repair. My A/C belt snapped while I was leaving the gas station the other day. I realized it immediately and pulled over to see what the problem was. The A/C belt had broken and wrapped itself around the fan. I bought both serpentine belts at the part store with the intention of replacing the other if upon inspection, saw that it needed it. I had the truck towed to my house where I began to check everything out.
The rear most serpentine belt that does the alternator, fan and idle I removed a found it to be in good shape. The front belt that operates the A/C compressor and the idle was shredded. So, I removed it from the center post of the fan and proceeded to loosen the manuel pulley so that I could get the new belt installed. Since I have manuel pulleys I had to adjust the tension myself. I've never had to so this before as my other vehicles have had the automatic tensioners.
My battery has been slow and sure been dying so I also replaced my battery because after installing the new belts I couldn't get the truck to turn over and stay running. Initially, I thought I needed to fine tune my belt adjustments and thought the new battery would give me the power I needed to start the truck.
Now it won't even turn over. It sounds very labored trying to turn over too boot. What I'm the hell could possibly be going on? I compared the tension of my belts to the tension of the belts in my partners vehicle and feel confident that I've got the adjustment right. But why won't it turn over now? Where should I begin diagnosing the problem? My starter? My alternator? It just has no "umph" when I turn the key. I did buy the battery used however, I had it tested before I left and the cranking amps were good and it's voltage was also good.
So, any ideas of where to start or simple suggestions that I might be overlooking?
Apr 20, 2021 at 11:32 AM
  • 110,251 POSTS
The belt tension isn't causing the issue. I need to know a bit more info. When you say it isn't starting now, is the starter still engaging but the engine failing to start, or does nothing happen when you turn the key to start?
If the starter isn't turning, take a look through this link and follow the procedure for testing the starter:
Next, if the starter does work and the vehicle just won't start, take a look through this link and let me know if it helps:
Both of these links are general in design because of different models. So, let me know what you find, exactly what is happening, and what has been checked so far.
Apr 21, 2021 at 1:09 PM
JESSBEEWRENCHIN
  • 6 POSTS
Wow!!! This is fantastic information! Thank you so much. I will get started first thing in the morning troubleshooting with what you've provided. It's exactly the information I was looking for but didn't know how or what to ask for. I will keep you posted and be back with any questions I might have as I go along.
Truly... thank you for the direction!!!
Jess B.
Apr 21, 2021 at 5:22 PM
JESSBEEWRENCHIN
  • 6 POSTS
Update: so I began by checking the fuses on the panel inside the cab located on the driver side. The fuses labeled inj and starter did not light up on either side of the fuse when checked with a test light. However when I pulled them upon inspection they both are intact and appeared to be in good shape. I've included an image. However I cannot seem to find my starter relay but I don't know if that's the next step to take in diagnosing the problem. Where do I go from here?
Apr 22, 2021 at 9:17 AM
JESSBEEWRENCHIN
  • 6 POSTS
Sorry I guess you get to look at those fuses twice. Lol
Apr 22, 2021 at 9:18 AM
STEVE W.
  • 15,420 POSTS
So you tested for power on both of those fuses and found none? Was that with the key on? How about with the key held in the start position?
If all you did was replace the belts I sort of suspect you accidently bumped a connector and caused a problem. Or as the belt came apart it damaged something.
As for a starter relay, your truck doesn't have one. It has the starter interlock on the clutch and it's relay as well as a cutout relay if it has the optional anti theft. I attached the wiring diagram so you can see the circuit. A fast way to see if the issue is on the starter side or in the switch side would be to pull the clutch interlock relay and jumper between terminals 3 and 5, then turn the key. Hold the clutch in and be sure it's in neutral to avoid any issues. If it now turns over you know the ignition switch, wiring and starter are okay.
Next would be to use a test light at the clutch switch just to be sure it didn't fail just for spite. One side of the switch (black wire) is grounded, it passes that ground through it when the pedal is down, so if you connect the test light to power you should get it to light on both terminals with the clutch pedal down.
Now if that works go back up to the interlock relay and connect the test light to battery power. It should light on terminals 1 and 5 if someone holds the clutch pedal down. If all of this works the issue isn't the circuitry, starter, ignition switch or interlock switch. It could be a bad relay though, especially if these all check out.
If it has the anti theft option it could be related to it as it cuts the starter circuit between the clutch switch and the relay. If your testing shows the switch good but the test light doesn't come on at terminal 1 with the clutch pressed it could be the anti-theft relay. To test it, you could simply pull it and jumper between pins 3 and 4. That completes the circuit and would show if the anti-theft relay or system is the issue.
Apr 22, 2021 at 9:56 AM
JESSBEEWRENCHIN
  • 6 POSTS
Update: I tested the clutch interlock relay and the relay itself tests fine. Where it plugs into has power but I wasn't able to conduct the test where I turn the key to the start position, press the clutch in and test terminal 3 and 5 to see if the test light came on because I was by myself. However I did replace the one hundred amp main battery fuse as well as the 40 amp battery fuse because by comparison they didn't look like the others. They weren't broken per se but they didn't look the same as their neighboring fuses. I checked the fuses underneath the driver side – again the air compressor fuse has one half of the fuse that is lighting up with a test light. My starter fuse doesn't light up at all however, the fuse is in good shape.
On a positive note is sounding much better whenever I try to start it. Whenever I turn the key over it is cranking. It is turning over it's just not firing up. Where to go to from here?
Apr 23, 2021 at 9:35 AM
  • 110,251 POSTS
If it is cranking, then we need to check to see if it has spark and fuel to the engine. Do me a favor. When it is cranking, see if it starts for a couple of seconds using starting fluid. If it does and then stalls, we know it is a fuel-related issue. If it makes no difference, then it is likely ignition-related.
Or, here are two links that show how to check fuel pressure and for ignition spark:
Also, since this just happened when the belts were replaced, I need you to confirm that the crankshaft position sensor is still attached. This is a long shot simply because it is located in the rear of the engine, but anything is possible. Also, confirm nothing has been disconnected from the distributor, The ignition coil/power transistor is located in the distributor.
See crank sensor location below.
Apr 23, 2021 at 11:13 AM
