Will not start
200,000 MILES • 3.5L • 6 CYL • 2WD • AUTOMATIC
CHRISCRINGLE
My son's car was running before the battery died and was sitting in the driveway until he finally bought a new one. Now the car won't start or even crank and the radio won't come on either, everything else comes on.. the dashboard lights, headlights, electric seats work, etc. I checked the starter fuse under dash and it's good. Is there a starter relay or is it a factory kill switch I don't know about?
Dec 10, 2019 at 8:14 AM
  • 110,248 POSTS
It could be a few things. First, see if it starts in neutral. Next, check the fuses I indicated in pic 1. Finally, there is a starter cut relay. Check it as well which is also shown in the picture.
When checking the fuse, confirm there is power to the fuse.
Here are a few links you may find helpful:
_______________________
Dec 10, 2019 at 11:55 AM
