Hello! With 180,000 miles on it, I would suspect a possible failed fuel pump. In my experience, when a GM/Delphi fuel goes, it goes without much warning. What you need to do is check for fuel pressure. Go down to your local auto parts shop and borrow a fuel pressure gauge. Take said gauge and hook it up to the test port at the end of the field rail. Turn the key to the run position and read the gauge. You need at least 41 psi to start your engine. Any less just won't cut it. I was going to get you Alldata's instructions on checking the pressure, but they're pretty technical and require some expensive tools that you probably don't have. Here is our general guide:
Start there and let me know what you find. If the fuel pressure is okay, return the pump and buy a spark tester (costs about $18.00 at the store, worth having around). Here's the one that I have:
https://www.amazon.com/Lisle-20610-Inline-Spark-Tester/dp/B0002STSC6
Mar 29, 2020 at 9:59 PM
