Will not start
190,000 MILES • V6 • 2WD • AUTOMATIC
RAASHIDA MUHAMMAD
The starter has been replaced and the battery is new, yet when the key is turned it just clicks one simple click. Lights and everything else work fine.what else should I do?
Dec 5, 2019 at 9:52 PM
  • 110,248 POSTS
First, confirm that the battery terminals are clean and tight. Also, make sure the grounds to the engine and body from the battery are clean and tight.
Next, check to see if the starter is getting power to the S terminal on the solenoid. That will be the smaller wire. Here is a link to help:
If there is no power to the S terminal, then check if the starter relay is bad. I attached two pics below to help you locate it.
Here is a link which explains how to test a relay. If there is another relay in the box with the same part number, switch the two to see if it makes a difference.
Here are a few other links you may find helpful:
Start with these things and let me know what you find. Since everything is new and you hear a click, I suspect it is going to be a connection issue. However, you need to check these things first. There is also a fusible link that can be bad, but we need these things done first.
Let me know if you have questions as well as what you find.
Dec 7, 2019 at 2:21 PM
