How long since a tune-up? Any applicable trouble codes? Having spark from coil is good, do you have spark at the plugs? Use a gauge and check proper fuel pressure, my information says 35--45 psi, so if your in the middle somewhere, you should be fine. I would also check fuel injector pulse. Fuel--spark--compression, proper amounts at the proper time.
SPONSORED LINKS
Sunday, September 17th, 2017 AT 12:37 PM
