Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
F-250
Engine
Symptoms
Not Running
Will not start after disconnecting the battery
1999 FORD F-250
226,500 MILES • 5.4L • V8 • 2WD • AUTOMATIC
SKYLAR CRUSE
MEMBER
1 POST
I disconnected the battery for about an hour and reconnect and the security light is flashing and won't start.
May 11, 2021 at 6:19 PM
Experienced Mechanic
Good morning,
I attached a guide for you to view for security reset. Try this and see if it works.
https://www.2carpros.com/articles/how-to-reset-a-security-system
If it does not, you will need a locksmith to come to you and reset the system. They need to use the Ford IDS software to reset the security.
Image (Click to enlarge)
May 11, 2021 at 8:23 PM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
