cranks no start no spark to the plugs
153,000 MILES • 5.3L • V8 • 2WD • AUTOMATIC
ERIC KING2
Engine turns over but will not start. I can hear the fuel pump prime, but do not have spark to plugs.
Dec 16, 2016 at 10:37 AM
SQM
  • 6,383 POSTS
A no spark will happen for a faulty ignition control module.
It can even happen due to a bad crank sensor.
There is also a ignition relay for this vehicle that can trigger no spark as well.
First item need to be checked is the ignition relay under the hood fuse block (see diagram).
If the relay is good check the control module.
The module can be tested. Just take it to your local part store and they will have the tool to do that.
You might find this article and the video helpful:
https://youtu.be/dCjmRL3p4Cs
Aug 8, 2021 at 2:14 PM
