Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Nissan
Xterra
Engine
Symptoms
Not Running
Will not start
2005 NISSAN XTERRA
173,053 MILES • 4.0L • V6 • 2WD • AUTOMATIC
MARK FOOTE
MEMBER
1 POST
The engine cranks, but won't start.
Nov 20, 2019 at 7:20 AM
Experienced Mechanic
When you have a crank no start condition, there are a limited number of things that can cause it. First, take a look through this link. It explains the most common causes of a crank no start.
If that doesn't help, you will need to check for spark and fuel to the engine. Here are links that explain how that is done:
Try these things first and let me know the results. Also, let me know if there were any symptoms prior to the no start.
Nov 21, 2019 at 8:44 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
