Will not start
173,053 MILES • 4.0L • V6 • 2WD • AUTOMATIC
MARK FOOTE
The engine cranks, but won't start.
Nov 20, 2019 at 7:20 AM
  • 110,248 POSTS
When you have a crank no start condition, there are a limited number of things that can cause it. First, take a look through this link. It explains the most common causes of a crank no start.
If that doesn't help, you will need to check for spark and fuel to the engine. Here are links that explain how that is done:
Try these things first and let me know the results. Also, let me know if there were any symptoms prior to the no start.
Nov 21, 2019 at 8:44 AM
