Engine shut off while driving will not start
211,000 MILES • 2.4L • 4 CYL • 2WD • MANUAL
STUCKINSUNCOUNTRY
Replaced fuel pump, still would not start. code reader said crankshaft position sensor no good, replaced that. still will not start. replaced fuel pump relay.. not sure what else would cause it to not turn over? Please help me before I go crazy and waste what little money I have!
I've looked at so many YouTube videos with no luck finding the issue.
Mar 2, 2020 at 11:12 PM
If you had a crank sensor code, that will cause this issue so what was the actual code.
I would suggest we start with the code because while it is a crank sensor code, other things could cause this to happen.
Let me know and we can go from there. Thanks
Mar 3, 2020 at 8:02 AM
