Will not start
176,458 MILES • 1.8L • 6 CYL • FWD • AUTOMATIC
TOM TANGIMETUA
Car will turn over, but will not start. I check spark to distributor it does not have spark. What can I check for?
Jun 28, 2017 at 3:34 PM
CARADIODOC
  • 34,415 POSTS
The place to start is by reading and recording the diagnostic fault codes. Here is a link that shows how you can do that yourself without a scanner:
https://www.2carpros.com/articles/mitsubishi-trouble-code-definitions-and-retrieval-procedure-for-odb1-system
The most likely suspects are the crankshaft position sensor and the camshaft position sensor. Mitsubishi has other names for those. We will worry about that once you have a fault code to tell us where to start.
Jun 28, 2017 at 3:52 PM
