Will not start?
138,000 MILES • 5.0L • V8 • 2WD • AUTOMATIC
ISLANDERP27
I have changed the distributer cap, rotor, fuel pump, coil, the truck still won’t start. checked the cam shaft sensor and all fuses, all good. Please let me know what else can be wrong.
Jul 19, 2023 at 2:07 PM
  • 110,248 POSTS
I need you to try something for me. See if the engine starts if you use starting fluid. If it does and then stalls, we know it is a fuel-related issue. If there is no change, then the problem is likely ignition related.
At this point, we need to check for spark at the plugs.
Here is a link that explains how it's done:
https://www.2carpros.com/articles/how-to-check-for-ignition-spark
Also, please confirm if this is a 5.2L, V8 for me.
Jul 20, 2023 at 12:29 PM
