wont start
14,500 MILES • 6 CYL
BLICKS AUTO
I just put a used engine in my car. I hooked everything up and try to start it, I have power I have fuel, starters good, batteries good, but it will not crank or start. I do not have power to the starter when the key is in the crank position the little wire on the starter that turns the cell annoyed has no power. I know it is electrical, but I do not know where to look first. what do I do to find the problem? everything is good on the car I have fuel I have electric to the spark plug,s but the car will not crank when I try to start it. I hear a clicking sound on the passenger side under the glove box. what do I do next? can someone please help me?
Aug 10, 2016 at 2:08 AM
SATURNTECH9
  • 30,868 POSTS
Have you checked all the fuses? you may have blown some fuses.
Aug 10, 2016 at 11:08 AM
BLICKS AUTO
all fuses are good fuel pump works, change camshaft sensor, crank sensor, relays in the fuse box in front of the battery. when I jump starter the engine cranks, but will not run. I took the engine out of a car that was hit in the front, the engine was not damaged it ran before I put it in the new car. The alarm is disabled so it is not that. the fuel fuel pump works, the coils work, the injectors work, everything works. it has to be electrical, but I do not know what to check next.
Aug 11, 2016 at 5:19 AM
SATURNTECH9
  • 30,868 POSTS
It is an automatic transmission car?
Aug 11, 2016 at 10:04 AM
