Will not start
160 MILES • 3.0L • V6 • 2WD • AUTOMATIC
DANGEROUSDON2002
I replaced the water pump and now it will not start. It has fuel and spark. When I crank it over and put the gas pedal to the floor it really tries to start but will not. Please help me, I need to get this van done and out of my garage. It acts like it is out of gas when starting but is not. I have spark at the coil and plugs.
Apr 15, 2018 at 12:35 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
How are you confirming it is getting fuel and spark?
Apr 15, 2018 at 12:39 AM
DANGEROUSDON2002
I have taken the return line off and cranked it over, also I have a light that plugs into the coil and the coil wire. when I am cranking the engine over the light flashes constantly until I let go of key.
Apr 15, 2018 at 12:43 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
Okay, but that does not mean the fuel injectors are working or even powered up. Check the fuel injector fuse, the ECM fuse, then check if there is voltage available to the fuel injectors with the key on run/engine off then last if need be, check with a noid light if the fuel injectors pulse when cranking the engine over with the starter. If there is a check engine light on, check for codes if you have not found the problem yet and of course if this has a anti-theft system and a security or theft light is on, try a spare key or try to clean that key where the pellet is and try again.
Or a quick test shoot a few shots of starting fluid into the throttle opening and try to start the engine, If it starts and runs for a few seconds, then most likely it is a fuel problem and the ignition is working just fine.
Apr 15, 2018 at 12:51 AM
DANGEROUSDON2002
Okay, I will give it a try. Thank you.
Apr 15, 2018 at 12:58 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
Okay, let me know if you run into any problems.
Apr 15, 2018 at 1:19 AM
DANGEROUSDON2002
I have checked the injectors wires and I have current to them. I put a test light on them and turned engine over and light pulsates. Still nothing is happening.
Apr 16, 2018 at 11:31 PM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
try cleaning off all the sparks plugs and try again. if it does not start immediately after cleaning all the spark plugs, try a few shots of starting fluid and let me know what happens.
I am reading that in order to replace the water pump you had to remove the timing belt. Are you sure you got the timing belt back on correctly?
Here are those timing marks again.
Apr 16, 2018 at 11:56 PM
