Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Explorer
Engine
Symptoms
Not Running
Will not start
1997 FORD EXPLORER
150,000 MILES • 4.0L • V6 • 4WD • AUTOMATIC
NYBRAT0927
MEMBER
1 POST
replace spark plugs and wire and ignition coil. put new starter and starter solenoid. now the truck wont start and no interior light.
Mar 29, 2021 at 5:19 AM
Experienced Mechanic
Good afternoon,
I would start by testing the battery and cleaning the battery cables.
Once you get power back, see if you can hear the fuel pump run for 2 seconds when you turn on the key.
I would also check the fuel pressure and test for spark as well.
I attached the wiring diagram of the system for you.
Images (Click to enlarge)
Mar 29, 2021 at 7:25 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
