Will not start
148,000 MILES • 3.1L • 6 CYL • 2WD • AUTOMATIC
DUSTY KRUEGER STRAUCH
Car had been having loss of power with EGR code registering. Now it will not start and i have replaced the EGR sensor. Also replaced the spark plugs, coils, crank sensor, and fuel pump and it has a good alternator.
Jan 24, 2017 at 5:35 PM
HMAC300
  • 48,601 POSTS
try a security system reset. then if still not starting have a mechanic scan for codes. see picture.
Jan 24, 2017 at 11:22 PM
RENEE L
  • 1,260 POSTS
Hello DUSTY KRUEGER STRAUCH,
I am sending you a link that if you decide to conduct the scan yourself will be of help to you. This link features an article with written step by step instructions and pictures explaining how to do the scan yourself, also I have included a link to our YouTube channel with a how to video on code scanning.
This is applicable even if your check engine light is not on.
Most scanners are inexpensive to purchase, you can purchase one online from sites like Amazon.com
https://youtu.be/YV3TRZwer8k
Once you have the codes please get back to us so that we can further assist you. We are always happy to help.
Thank you for visiting 2CarPros.com.
Kindest regards,
Renee
Admin
Jan 25, 2017 at 1:44 AM
I have done the security reset and got nothing. Spayed some starting fluid in and it started up. My fuel line is stopped up. Thanks for the information though.
Jan 25, 2017 at 4:43 AM
HMAC300
  • 48,601 POSTS
if line is plugged then it will never start. you will have to find out where it is plugged, maybe a hose has collapsed inside. plugged fuel filter etc. also, check return lines as they will cause same thing.
Jan 25, 2017 at 5:02 AM
