Battery keeps going dead, also no start issue
100,000 MILES • 3.7L • 6 CYL • 2WD • AUTOMATIC
MAXPOWER1331
Last Monday my truck wouldn’t start due to a dead battery. for some reason even with the key not in the ignition the battery was drained my my iPhone being plugged in it jumped right away no problems for two days. Two days later with nothing plugged in or any lights left on the battery was dead again (I thought). All the interior lights and radio would come on and work just fine but when I turned the key nothing happened , no clicking , no cranking , just nothing. I tried jumping it and found the positive terminal was loose so I tightened it and eventually it started and worked all day (turned off and started back up fine multiple times). The next day, the same thing happened; all the lights and radio worked but nothing would happen when I turned the key. Tried jumping it and it started right away. I went to my uncles to try and clean up the terminals a little and it worked for a little while. I had it off while working and it started back up just fine a few hours after cleaning the terminals... a couple more hours later , I tried to go home and it wouldn’t start ( same situation all the lights work , radio, but no clicking or cranking). tried jumping it , this time it wouldn’t jump, tried putting in a different fully charged battery and that made no difference either. also for some reason if I haven’t already alluded to it , something is draining the battery when the key isn’t even in it. not sure if that is relates but it seems like a short or something but I have no idea where to even begin on this and unfortunately I only have a few days to fix it or I’m SOL. Any help would be greatly appreciated. I am currently not with the vehicle as it is stuck at my uncles but I’m trying to get back over there today ASAP.
Jun 30, 2019 at 1:06 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
I have a few suggestions. First you might want to have your battery load tested and your alternator out put tested.Most auto parts store will test for free. Here are tutorials showing what is involved with those two things:
If you test and they check okay here is what to do next to check for a battery drain. You will need a to use a test light. Here is a tutorial showing how to use:
Using the test light disconnect the negative battery terminal.Keep the test light in line with the cable end and battery terminal. If there is a drain the light will be slightly lit. Remove the fuses one at a time and when the light goes out that will show you which circuit is causing the drain. Hope this helps and thanks for using 2CarPros.
Danny-
Jun 30, 2019 at 11:36 AM
