when I pulled into driveway cut it off and it has not started
185,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
DEHARTN
just bought the car, drove it the first time and when I pulled into driveway cut it off and it has not started since.
Sep 24, 2017 at 1:10 PM
STEVE W.
  • 15,421 POSTS
OK sounds like you lost spark. To test that and compression at the same time. Go to the parts store and "rent" a compression tester and a spark tester (or if you plan on doing your own or friends cars buy them).
The spark tester gets hooked up between the spark plug wire and ground.
Turn the key and hold the throttle wide open. Have someone watch the spark tester and the compression gauge.
If they see no spark but the compression gauge goes up to 110-130 PSI, you don't have spark but the timing parts and engine are OK as the compression relies on those parts working. This engine uses a chain that doesn't fail often but they can.
Ignition wise a common failure is the crank position sensor. Not hard to replace, but you need to use a good scan tool to reset the sensors info.
Sep 28, 2017 at 1:46 AM
DEHARTN
i have spark and good compression. i have replaced the crankshaft position switch. I need the engine wiring please?
Sep 28, 2017 at 11:48 AM
  • 55,808 POSTS
It sounds like we have lost power somewhere. Here are a couple of guides and diagrams (Below) for you to do some easy checks and report back. There are 6 fuses that run the system.
ERLS, CLS-PCM, PCM/IGN, F/P INJ, IGN, PCM
and
Please let us know what you find.
Cheers, Ken
Oct 4, 2017 at 7:16 AM
DEHARTN
I found i short in the main harness where is rubbed through. all set thank you.
Oct 11, 2017 at 1:44 PM
