Wont start
145,000 MILES • 4.7L • V8 • 4WD • AUTOMATIC
DANIELP319
I checked the gas gauge when my wife said it would not start, it was on empty. I put two gallons of gas in it and it started right up. Problem solved right?
We ran it for a day and parked it for the evening. Next morning it would not start. Fuel pump right? or perhaps bad gas.
I bought STP fuel treatment and starter fluid. I put the STP in the tank and sprayed the starter fluid into the air intake. After several attempts it started, hooray! Problem solved.
Not hardly, we ran it for about an hour hoping to get the "bad gas" out of the tank. Parked it in the driveway and the following morning it would not start.
After some research on the internet I found several articles that caused me to believe it was a cam shaft positioning sensor,.. I replaced it and still wont start. I also replaced the cable going from the positive terminal into the computer box. It started and we ran it for several hours afraid to turn it off it did, however stalled and cut out after about an hour and ten minuets of driving it.
I am at a loss and need some professional advice.
Please help!
Thank you,
Daniel
Jun 6, 2016 at 4:27 AM
HMAC300
  • 48,601 POSTS
have it scanned for codes , auto parts does for free , and check fuel pressure with a gauge auto parts rent it. it may be from running out of gas as pump is cooled by gas.
Jun 6, 2016 at 5:08 AM
DANIELP319
I am sorry, I obviously did not give enough information, After it started there was over half a tank of gas.
Jun 6, 2016 at 5:13 AM
HMAC300
  • 48,601 POSTS
yes but you ran it empty and electric fuel pumps use fuel for cooling so I t may be drawing to many amps or not performing enough pressure or make the car run right. You need to check the fuel pressure with a gauge. You will need to do that anyhow to see what is wrong.
Jun 6, 2016 at 5:35 AM
