Engine cranks but does not start
184,000 MILES
TFAJRA
Car was running prefect. Got out got back in wouldn’t start. Now it cranks but won’t start.
Jul 7, 2022 at 6:51 AM
  • 110,244 POSTS
Chances are you either lost ignition spark to the plugs or fuel. Here is what I need you to try. See if it starts for a couple of seconds if you use starting fluid. If it does then stalls, we know its fuel related. If there is no change, then suspect it is ignition related.
Here is a link that explains how to check for an ignition spark. Perform this if there is no change with the starting fluid.
https://www.2carpros.com/articles/how-to-check-for-ignition-spark
Here is an additional link you may find helpful:
https://www.2carpros.com/articles/car-not-running-advanced
Let me know what you find so I know which way to direct you.
Jul 7, 2022 at 7:53 AM
