Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Mercury
Grand Marquis
Trouble Codes
OBD1 Codes
Code 14
OBD codes 14 and 34, Engine turns over fine, but not a hint of firing?
1989 MERCURY GRAND MARQUIS
100,000 MILES • 5.0L • V8 • 2WD • AUTOMATIC
SDPLASKO
MEMBER
Engine turns over fine, but not a hint of firing. OBD codes 14 and 34.
May 23, 2023 at 2:44 AM
Experienced Mechanic
I would replace the MAF and coolant sensors here is what is said about the codes:
OBD Code 14: This code indicates a problem with the Engine Coolant Temperature (ECT) sensor or circuit.
OBD Code 34: This code indicates a problem with the Mass Air Flow (MAF) sensor or circuit.
May 23, 2023 at 6:45 AM
SDPLASKO
MEMBER
Thanks for your input. I will update you with the results.
May 23, 2023 at 5:25 PM
May 25, 2023 at 9:59 AM
Add image or video
Ask a new question
Check engine light
Engine won't start
