Will not start?
200,000 MILES • 3.0L • V6 • 4WD • AUTOMATIC
SANRAE74
Replace fuel pump, relay, checked fuel pressure, made sure fuel pump was working. It did start, drove it up the drive and back, next morning it won't start.
Aug 8, 2022 at 3:07 PM
  • 110,244 POSTS
Do me a favor. See if it will start with starting fluid. If it does and then stalls, we know its fuel related. I realize you replaced the fuel pump, but it could be related to the injectors.
If there is no change whatsoever, confirm there is spark to the plugs.
Here is a link that shows how to check:
https://www.2carpros.com/articles/how-to-check-for-ignition-spark
Try this so we can narrow things down and let me know what you find.
Aug 8, 2022 at 5:10 PM
  • 110,244 POSTS
I noticed it has been a few days since I heard from you. Have you been able to make any progress?
Aug 14, 2022 at 12:35 PM
