Will not start
128,372 MILES • 2.0L • 6 CYL • 2WD
CRAZYGRANNY T
Car was given to me.It has set for three years. gas smelled like turpentine. I changed filter and fuel pump and still won't start. I've tried start it with starting fluid and it wants to but never catches. Help anyone! it's a 2.8 not 2.0.
Aug 3, 2019 at 2:16 PM
  • 110,248 POSTS
Welcome to 2CarPros.
When you say when using starting fluid it wants to but never catches, is the engine firing? Are you sure it is getting spark? If it is, have you checked to see if the injectors are clean and not plugged?
Take a look through these links and see if they help.
https://www.2carpros.com/articles/how-to-test-a-fuel-injector
Also, I realize the fuel pump is new, but have you confirmed the fuel pressure at the engine is within spec?
Here are the manufacturer's specs.
Fuel Pressure [1] .................... 284 - 325 kPa (41 - 47 psi)
[1] With the ignition "ON" and engine "OFF" (zero vacuum)
Aug 3, 2019 at 2:58 PM
CRAZYGRANNY T
Still trying and yes fuel pressurized test that's good. waiting on friend to help with injectors. I'll keep you posted. thank you
Aug 5, 2019 at 11:37 AM
  • 55,740 POSTS
Did you drain the old gas out and install fresh fuel? If so does it run on starting fluid?
This guide should help us:
Aug 8, 2019 at 5:27 AM
