Will not start
165,000 MILES • 1.8L • 4 CYL • TURBO • 2WD • MANUAL
DAVID A SHAW
Was doing work on the sunroof took the headliner out but it’s still in the open position but when I put it back on and I think the #79 relay for the sunroof/“power windows and doors” failed and somehow my actuator in my trunk latch started to move back and forth in a stuck motion and won’t stop unless I smash it shut or disconnect the wire from it but If I go to start the car the truck latch opens and doesn’t let me start. I think it’s something to do with my anti theft and the fact that my door latches don’t work why my key to enable the alarm but I can unlock them but I can use my key to enable and disable the alarm from the trunk but it won’t right now because it is moving back and forth and doesn’t disable. I also pulled out the #214 relay cause at first that one felt like it was clicking but it looked like it needed to be replaced also.
Mar 5, 2019 at 8:33 AM
  • 55,746 POSTS
It sounds like you removed a ground wire in the system when you were doing the work? Lets run the codes to see what comes up to point us in the right direction.
Mar 7, 2019 at 2:01 AM
