Will not start
2012 KIA SOUL
83,000 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
JAYJAYC440
Car will not start just one click. battery is good. had a smell of wires burning when tried to start. was able to jump starter to get it home. Is the problem the starter solenoid?
Nov 7, 2017 at 5:37 AM
KHLOW2008
  • 41,814 POSTS
If you can jump start the vehicle, it is not a starter problem. Most likely the battery connections or ground cables are loose or bad.
Have the battery tested, it could be weak causing the problem.
Nov 7, 2017 at 12:30 PM
