Will not start, I replaced the starter, fuel pump?
110 MILES • 4.6L • V8 • 4WD • AUTOMATIC
JAKXWESTHOFF
i replaced the starter, fuel pump, fuel tank, fuel regulator and it still wont start unless you poor gas into the throttle body. i have reset the emergency shut off.
Jul 2, 2020 at 9:49 PM
Good morning,
Can you hear the fuel pump run when you turn the key on?
Did you verify power to the pump?
Do you have a voltmeter or test light to do some checks?
May 31, 2021 at 5:40 AM
