WON'T START
206,000 MILES
PINTOSPARTY
Have a no start problem on a 93' nissan quest. started out a a sputtering then got worse, then finally stalled and wont start back up. We have replaced the timing belt, fuel filter, all spark plugs, rotor, cap, distributor and ignition coil. but i still isn't starting. oh and yes the fuel pump is working. I'm lost, please help!
Apr 18, 2013 at 4:30 AM
DRCRANKNWRENCH
  • 3,380 POSTS
You may have a clogged catalytic converter. You can check it by banging on it with your hand and listen for loose material moving anround. I am also giving you a walk through diagnostic that might help as it covers the most likely issues and there may be something that can help. Just use the link below'
Apr 18, 2013 at 1:23 PM
