Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ram
1500
Engine
Symptoms
Not Running
Will not start
2003 RAM 1500
220,000 MILES • 5.9L • V8 • 4WD • AUTOMATIC
BROKE DODGE
MEMBER
1 POST
Truck cranks over but won’t start. New fuel pump, crank sensor and cam sensor.
Oct 1, 2019 at 10:19 AM
Experienced Mechanic
Welcome to 2CarPros.
Have you checked to see what is missing? For example, have you checked for spark to the plugs or have you checked fuel pressure?
What I suggest is to start by determining what is missing. Here are links that explain how to check for both spark and fuel:
If you determine that both are working properly, then I need you to check if there is an injector pulse. Here is a link that explains how to check the injectors:
https://www.2carpros.com/articles/how-to-test-a-fuel-injector
Oct 1, 2019 at 12:00 PM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
