Will not start after replacing the clutch
200,000 MILES • 0.5L • 6 CYL • 2WD • MANUAL
LAKENYA NICOLE
I have the car listed above SE model. I recently replaced the clutch and have been having problems getting it started ever since. It use to start after 2 or 3 times then it just increased from there (4 to 5 times) now it won’t start at all. I’ve replaced the starter, alternator, and crank shaft sensor and still nothing. I’ve listen for the fuel pump when turning the car over and it comes on. Someone please help?
Mar 10, 2020 at 9:27 AM
Good morning,
Does the engine crank over when it will not start or does nothing happen when you turn it to start?
Did you verify the battery voltage?
Mar 10, 2020 at 7:48 PM
LAKENYA NICOLE
Yea it cranks over. It actually sounds like it wants to start it just never catches once your turning the key. The battery is new just replaced it 2 weeks ago.
Mar 11, 2020 at 4:19 AM
