Hey CORSAMAD,
From what i can see there is a gas/petrol vehicle?
I would advise trying turning the ignition on and leaving it on for around 30 seconds, turn the ignition off and then repeat this cycles 4-5 times. Then attempt to start.
This may allow the system to prime enough to get it to start.
While you have the ignition on get someone to listen at the fuel filler, can they hear the fuel pump running? There should be a buzzing coming from the fuel tank that marks the pump operating.
No buzzing indicates a pump issue.
If the pump is running but it will not start i would say you potentially have a blocked fuel filter
I don't have the specifics for your vehicle here but i there is a guide in the link below that shows this process:
https://www.2carpros.com/articles/how-to-change-a-fuel-filter
Let us know how what you find here.
Regards, Joe
Feb 20, 2020 at 5:11 AM
