Cranks will not start
150,000 MILES • 3.6L • 6 CYL • 2WD • AUTOMATIC
BESTES
Car cranks but will not start, but if I unplug mass air flow I can get it to run and idle. I installed two new MAF sensors on it.
Sep 8, 2018 at 3:19 AM
  • 55,721 POSTS
It sounds like the PCM is going out, but to be sure lets run the codes. Here is a guide to help get us started:
Cheers, Ken
Sep 9, 2018 at 6:17 AM
BESTES
What you looking for I have done this already shows p0102, p2229, and p0113. And sometimes it show crank sensor code but has been replaced.
Sep 10, 2018 at 12:45 AM
  • 55,721 POSTS
These are three different sensor issues and the fact the crankshaft codes comes and goes tells me PCM. Can you tell me if the car has had any wiring repairs or modifications done?
Sep 10, 2018 at 4:06 AM
