Will not start
197,000 MILES • 3.3L • V6 • 2WD • AUTOMATIC
DAVID NIKEL
  • 6 POSTS
I have spark, gas, and air, but it won't start. Did this for a day so I changed the spark plugs and wires as it was time to do so, it ran for a day and then stopped. It doesn't have any codes showing up. I've even tried starting with brake clean which has not done anything.
Mileage is in km so is approximately 120,000 miles.
Feb 12, 2021 at 10:36 AM
  • 110,248 POSTS
If it won't start with starting fluid, chances are there is no spark to the plugs, we lost compression or timing. Can you do me a favor? Record it cranking and upload it for me to hear. Hopefully, I will be able to determine if there is a compression or timing issue
Here is a link that explains the most common causes of a crank no start. Take a look through it and see if anything helps.
I realize you indicated there is spark. Make sure it is a good hot blue snapping spark. If it is white or orange, it may not be hot enough to ignite the fuel.
Take care and God Bless,
Feb 12, 2021 at 12:05 PM
DAVID NIKEL
  • 6 POSTS
https://linksharing.samsungcloud.com/iY1JR6nJ31ZL
The spark was strong and blue, the coil for 1/4 seemed to be a little weaker but still strong enough. I got my hands on a compression tester so I will give that a go
Feb 13, 2021 at 1:27 AM
  • 110,248 POSTS
Listening to it crank, it doesn't sound like compression, but it would be a good idea to check. To me, it sounds like a fuel related issue. You mentioned it wouldn't start with brake cleaner. Have you tried starting fluid? Also, have you checked fuel pressure?
Feb 13, 2021 at 10:47 AM
DAVID NIKEL
  • 6 POSTS
I've checked for pressure but I haven't check the injectors. I haven't tried a specific starting fluid. I talked to some local guys and they say the ignition modules go bad and then the ignition timing is off. They also told me they use brake fluid to rule out fuel in non starts.
Feb 13, 2021 at 1:17 PM
  • 110,248 POSTS
Brake fluid? I'm not sure what that would be used for. What I would suggest is to reconfirm ignition spark to the plugs. As far as the ignition module, it is under the coils. Here are directions for replacement.
The attached pic correlates with the directions.
______________________________
1993 Oldsmobile Cutlass Ciera V6-3300 3.3L MFI VIN N
Ignition Module Replacement
Vehicle Powertrain Management Relays and Modules - Powertrain Management Relays and Modules - Ignition System Ignition Control Module Service and Repair Procedures Ignition Module Replacement
IGNITION MODULE REPLACEMENT
Dielectric Grease Application
pic 1
REMOVAL
1. Disconnect negative battery cable.
2. Disconnect DIS electrical connectors.
3. Disconnect spark plug wires. (Note proper relationship of wires to coils).
4. Remove DIS assembly to block bolts (3).
5. Remove DIS assembly from engine.
INSTALLATION
1. Install DIS assembly to engine.
2. Install DIS assembly to block bolts (3). Torque to 20-30 Nm (15-22 lbs ft).
3. Connect spark plug wires to proper coils.
4. Connect DIS electrical connectors.
5. Connect negative battery cable.
_______________________________________________________
I hope this helps you. Please let me know if you have other questions. I believe some of the parts stores have the ability to test the module, so you may want to have it checked before replacement.
Feb 14, 2021 at 8:31 AM
DAVID NIKEL
  • 6 POSTS
After changing the unit I have gotten it to run for a second or two 2 times, but it still doesn't run.
Feb 16, 2021 at 9:31 AM
  • 110,248 POSTS
If you still have a good spark, then it sounds fuel-related. See if it starts with starting fluid. If it doesn't, here is a link that explains how to test fuel injectors. You indicated the fuel pressure is good. See if there is a signal to the injectors.
https://www.2carpros.com/articles/how-to-test-a-fuel-injector
Please reconfirm spark. Also, have you replaced the crankshaft position sensor?
Feb 16, 2021 at 10:32 AM
DAVID NIKEL
  • 6 POSTS
Coil 1/4 no longer have spark after replacing the module. I will test my injectors tomorrow. I ruled out the crank position sensor assuming if it was faulty it would throw a code and when I checked nothing came up. If this is not the case I will also look into it.
Feb 16, 2021 at 12:11 PM
  • 110,248 POSTS
The crank sensor may not set a code. Take a look through this link:
If you aren't getting spark, that needs fixed regardless of fuel.
Feb 17, 2021 at 7:17 AM
