Will not start
200,000 MILES • 1.0L • 6 CYL • 2WD • AUTOMATIC
RYAN G
  • 5 POSTS
Have a start relay you turn on prior to starting. now i try to start and it tries barely to turn over and negative cable is smoking. Please help!
Jan 13, 2018 at 7:29 AM
CJ MEDEVAC
  • 11,000 POSTS
Please explain this part in better detail (as this does not sound like a 'normal' thing).
"Have a start relay you turn on prior to starting"
Help me to understand!
The Medic
Jan 13, 2018 at 8:14 AM
RYAN G
  • 5 POSTS
Yes, it is some kind of after market turn off switch. turn it on and everything turns on fine, then out of nowhere it started acting like a drained/draining battery. Tried two new batteries and same thing. The back cable is so hot it smokes (battery cable). Thank you for any help! Ryan
Jan 13, 2018 at 8:29 AM
RYAN G
  • 5 POSTS
Black cable.
Jan 13, 2018 at 8:30 AM
CJ MEDEVAC
  • 11,000 POSTS
RYAN G
  • 5 POSTS
No, :/ it is a red key type after market anti theft switch. Honesty has nothing to do with this issue. If i try and start the car it acts like it wants to crank but will not, like the battery, but tried two new ones and same thing. Can i bump/hit starter? Why is negative battery cable so hot/smoking?
Jan 13, 2018 at 8:49 AM
CJ MEDEVAC
  • 11,000 POSTS
Why was this put on to begin with?
Which side of the battery is it hooked to, positive or negative?
Like this, sort of, kind of, maybe?
http://www.wirthco.com/batterydisconnectbatteryswitches/batterydisconnectsquickreleaseswitches.html
Starter could be bad-maybe.
I am thinking a poor connection.
Not enough juice or ground for the starter
Let's look at this stuff first.
See any corrosion?
Grab and twist/see if the there is movement of the cables on the other side of a clamp. Grab twist all battery cable connections to anything (both ends of each cable) There should be no movement!
My link may explain better/ I made pictures at the end of it.
https://www.2carpros.com/questions/1996-chevrolet-tahoe-wont-start-sounds-dead-battery-jumpbox-get-same-reults
The Medic
Jan 13, 2018 at 9:05 AM
  • 55,743 POSTS
Battery cable hot and smoking can only mean one of two things either the cable had a bad connection or there is too many amps being pulled through the cable. Can you please upload a picture of the part in question so we can see what you are talking about?
Here is a general guide that can help look toward the bottom of the guide:
Cheers, Ken
Jan 13, 2018 at 9:42 AM
CJ MEDEVAC
  • 11,000 POSTS
RYAN G,
Gotta always come back to "your thread", gets confusing when you add on to another.
Even more confusing for a guest looking at your problem trying to find an answer to theirs!
"The Boss" (not Bruce Springsteen)
Has answered you above this/my answer.
Thanks!
The Medic
Jan 13, 2018 at 11:14 AM
