Will not start
260,000 MILES • 1.4L • 2WD • AUTOMATIC
HELP-JOEL
It turns over, but won't start.. Fuel pump runs, if I feather the gas pedal it starts but won't idle unless I feather pedal.
Oct 6, 2020 at 9:18 PM
Good morning,
I would start by checking the actual fuel pressure to be sure the proper fuel pressure is delivered to the injectors.
https://www.2carpros.com/articles/stall-at-idle
Is the check engine light on? If it is, do you knw the codes?
Oct 7, 2020 at 12:45 AM
