Will not start
110,000 MILES • 4.7L • 2WD • AUTOMATIC
TERRYT81
The vehicle wont start unless it's jumped off and even when that happens the alarm goes off and prevents it from starting properly. What do you think?
Also the electrical windows don't work and there is an after market stereo in the vehicle that works. What you think?
Jun 9, 2020 at 4:21 PM
Good morning,
This sounds like a low voltage from the battery.
I would start by charging the battery to 12.6 volts and then start it.
https://www.2carpros.com/articles/how-to-charge-your-car-battery
Then I would check the charging system to see if the alternator is working.
Jun 9, 2020 at 6:50 PM
