Cranks but wont start
2,230,000 MILES • 2.0L • 4 CYL • 2WD • MANUAL
DILL-11
  • 126 POSTS
cranks over but no fire to plugs and no start.
Nov 16, 2016 at 10:36 AM
AL514
  • 5,700 POSTS
are you getting a check engine light while cranking the engine over? could be possibly be PCM power relay or failed ignition coil.
Nov 16, 2016 at 11:21 AM
DILL-11
  • 126 POSTS
Yes, the check engine light on while trying to crank it. Also, I have replaced the coil. Where is the PCM power relay located?
Nov 17, 2016 at 1:51 AM
AL514
  • 5,700 POSTS
well if your check engine light is coming on your getting power to the ECM, here is two checks, first check for power at the coil (first diagram, should be 12 volts), second check the crank sensor for a pulse while turning the engine over. It is powered up on the grey wire. The crank sensor will stop your ignition if its not sending a signal to the ECM.
Nov 17, 2016 at 4:27 AM
AL514
  • 5,700 POSTS
well if your check engine light is coming on your getting power to the ECM, heres 2 checks, first check for power at the coil (first diagram, should be 12volts), 2nd check the crank sensor for a pulse while turning the engine over. Its powered up on the grey wire. The crank sensor will stop your ignition if its not sending a signal to the ECM.
DILL-11
  • 126 POSTS
Well the engine belt broke and tangle up around the crank and other pulley could it have got on the crank sensor? I cannot see the crank sensor.
Nov 17, 2016 at 9:02 AM
AL514
  • 5,700 POSTS
so you have replaced the broken timing belt and now it wont start?
Nov 19, 2016 at 3:24 AM
AL514
  • 5,700 POSTS
It appears the cranksensor is on the rear of the engine block, near the flywheel, This varies on some models but yours should be on the bell housing. Look for the Grey and Blue wire connector at the sensor, the colors change to Black and White down the circuit at a connector on the harness . Its only a 2 wire sensor. You can check it for power and a pulse coming from it while cranking. Also check that ignition coil for power. Make sure you didn't blow any fuses or anything basic like that as well.
Nov 19, 2016 at 3:42 AM
