Will not start
75,000 MILES • 4.1L • 6 CYL • 4WD • MANUAL
JIMMAC21
Parked okay a week ago. Now no dash lights/radio/wipers. batteries both okay measure 12.5 volts with headlights on full. No noise from starter motor. No 12 volts on three terminals in terminal block on LHS just in front of battery.
Dec 15, 2019 at 3:00 PM
AL514
  • 5,683 POSTS
Hello, have you gone through and checked every fuse with the key on? If you're missing power, that's where to start. Check all fuse blocks under the hood and under the dashboard. And let us know the results
Dec 15, 2019 at 11:10 PM
JIMMAC21
Yes, I checked fuses. It turned out to be a corroded (small) cable on the 12V positive battery terminal hidden under the heavy starter motor cables.
Thanks for your help anyway.
Dec 17, 2019 at 9:04 AM
AL514
  • 5,683 POSTS
You're welcome, let us know if there's anything else we can help out with.
Dec 18, 2019 at 5:37 AM
JIMMAC21
Thanks. I've since discovered that what was corroded was one of the fusible links which I will now replace.
Dec 18, 2019 at 9:02 AM
AL514
  • 5,683 POSTS
Yeah they get corroded inside and fail all the time. thanks for using 2CarPros.
Dec 18, 2019 at 8:03 PM
