Obd ll code said cam position sensor. Replaced sensor and connector. Still no start, still cam position sensor code.
Jun 27, 2017 at 2:21 AM
✓Experienced Mechanic
Does the engine sounds normal when it is turning over or does it sounds like it is very easy. Please run a compression test to see if the engine is okay.
Here is a guide to ehlp you get the problem fixed.
