p1258?
2005 CHEVROLET SILVERADO
250,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
STEVEHINSON5
  • 8 POSTS
Showed overheat protective code is active. checked for water leak, now will not start. also, found oil on harness at bottom of fuse box on firewall and in plug going to computer. no oil in computer and all fuses are good and getting power but will not start.
Dec 19, 2017 at 7:28 AM
  • CAR REPAIR CONTRIBUTOR
Good morning my name is Roy and I will assist.
What is the code number that has set???
oil at those locations is not good. remove the connectors and clean the connections with something like break kleen. Inspect the terminals for any damaged or loose pins. Use electrolytic grease in the connector when putting it back together to ensure good connections.
Also, do you know if you have spark and fuel pressure?. You need spark, fuel, and compression to make the engine run.
Dec 20, 2017 at 6:41 AM
STEVEHINSON5
  • 8 POSTS
I do not have fire to plugs checked all fuses and have fire to them could it possibly be computer
Dec 20, 2017 at 7:25 AM
That is the last thing that could be the failure.
When you crank the engine from inside the truck, does the tach move up a little showing low rpm???
Dec 20, 2017 at 7:28 AM
STEVEHINSON5
  • 8 POSTS
No but if u hold ignition switch down it will quit turning over by its self like u let up on ignition switch
Dec 20, 2017 at 7:50 AM
STEVEHINSON5
  • 8 POSTS
Also oil pressure was fluctuating before this
Dec 20, 2017 at 7:52 AM
Ok, if you have no tach signal, chances are you may have a failed crank sensor. that is what sends the signal to the PCM. once the PCM sees this signal, it will turn on spark and the fuel pump.
Do you have a scan tool to read live data???
Dec 20, 2017 at 8:05 AM
STEVEHINSON5
  • 8 POSTS
I have a scan tool but how do u read live data with it not running
Dec 20, 2017 at 8:20 PM
OK first what are the codes??
When cranking does it show engin RPM while cranking???
Dec 21, 2017 at 3:20 AM
STEVEHINSON5
  • 8 POSTS
P1258 and i am not around truck supposedly being looked at but has been there 4 days not a word i will find out if rpm moves or not i really appreciate the input you have given me
Dec 21, 2017 at 6:10 AM
Ok. did it overheat???
Did they do any checks at all?? Fuel pressure, compression and check for spark?? Below is a description for the code but does not look like it is the reason for no start.
DTC P1258
Circuit Description
The Powertrain Control Module (PCM) uses the ECT sensor to monitor the engine for an over temperature condition. This condition occurs when the coolant temperature is above 132° C (270° F). When an over temperature condition is present, DTC P1258 will set. The PCM will disable two groups of four cylinders by turning OFF the fuel injectors. By switching between the 2 groups of cylinders, the PCM is able to reduce the temperature of the coolant.
DTC Descriptor
This diagnostic procedure supports the following DTC:
DTC P1258 Engine Coolant Overtemperature - Protection Mode Active
Conditions for Running the DTC
^ DTCs P0117, P0118, P1114, and P1115 are not active.
^ The engine is running.
Conditions for Setting the DTC
The engine coolant temperature is above 132° C (270° F) for 10 seconds or more.
Action Taken When the DTC Sets
^ The PCM will illuminate the Malfunction Indicator Lamp (MIL) during the first trip in which the diagnostic test has been run and failed.
^ The PCM will signal the Instrument Panel Cluster (IPC) to turn ON the Service Engine Soon indicator.
^ The PCM will alternately disable two groups of four cylinders by turning OFF the fuel injectors.
^ The PCM will store conditions which were present when the DTC set as Freeze Frame and File Records data.
Conditions for Clearing the MIL/DTC
^ The PCM will turn the MIL OFF after 3 consecutive trips that the diagnostic has been run and passed.
^ The history DTC will clear after 40 consecutive warm-up cycles have occurred without a malfunction.
^ The DTC can be cleared by using the scan tool Clear DTC Information function.
Dec 21, 2017 at 6:20 AM
STEVEHINSON5
  • 8 POSTS
A little more info the tach does not move. Also in my house fire i lost keys turns out someone had changed ignition tumbler so mech put a different steering colum in and had to reprogram it so truck would start is it possible that it has lost memory of that and needs to be reprogrammed
Dec 21, 2017 at 8:35 AM
Yes, if he removed the battery cable. If that was the case he just needs to do a re learn procedure
Dec 21, 2017 at 8:38 AM
STEVEHINSON5
  • 8 POSTS
Will try that
Dec 21, 2017 at 9:23 AM
Sounds like a plan
Dec 21, 2017 at 9:24 AM
