Alarm kept going off, and now it will not start at all. Will not even turn over.
200,000 MILES • 4 CYL • FWD • AUTOMATIC
CHRISTY TALLENT
Car was not running right it was not getting enough power. i tried the battery cables first. When I took the negative off and put it back. Alarm kept going off, and now it will not start at all. will not even turn over.
Oct 25, 2016 at 8:33 AM
AL514
  • 5,700 POSTS
The car wont turn over because you probably need to reset the alarm system.
https://www.2carpros.com/articles/how-to-reset-a-security-system
If okay his sounds like the starter is having problems or the battery needs to be load tested these guides can help us fix it.
and
Oct 25, 2016 at 9:26 AM
