Will not start
100,000 MILES • 6 CYL • 2WD • AUTOMATIC
TOM WILEY III
The on button is lit up. It just cranks and will not start.
Jul 17, 2018 at 4:36 AM
  • 55,781 POSTS
It sounds like you have a crankshaft angle sensor that has gone out which is common. When these sensors fail they may not trigger a check engine light. When you turn the key to the on position without starting the engine can you hear the fuel pump prime? If so I would do the crankshaft sensor. Here is a guide to help you see what you are in for when doing the job and diagrams below so you can see the location for your car:
Cheers, Ken
Jul 18, 2018 at 11:05 AM
