My starter does not work when I turn the key?
190,000 MILES • 3.1L • V6 • 2WD • AUTOMATIC
WILLING1995
The car doesn't even try to crank so I know it is not the VAT problem. Brand new battery, ignition cylinder, and ignition switch. all the accessories work fine. car has run fine before this and is serviced properly. what else should i look at? i am stumped.
Apr 13, 2019 at 4:47 AM
SCGRANTURISMO
  • 4,897 POSTS
Did you check the IGN SW BAT 1(40A) fuse in the Underhood Fuse Block in the left hand side of the engine compartment? I have included diagrams in the diagrams below for you as well as a link down below for you to go to:
Please go through the guides and get back to us with what you are able to find out please.
If okay it sounds like the battery is weak or the starter has gone out but to be sure lets check out these guides, they can help us fix it
and
Check out the diagrams (Below). Let us know what happens and please upload pictures or videos of the problem.
Apr 13, 2019 at 9:33 AM
WILLING1995
i had not checked that yet, but i have spent today verifying all fuses and relays in all three fuse boxes are good. what else could it be?
Apr 14, 2019 at 5:10 AM
SCGRANTURISMO
  • 4,897 POSTS
Hello again,
Okay don't worry. We will get this, no problem. Let's start at the basics. This is just going to be a simple process of elimination, and in the end we will be precisely at the problem, so have heart, but also a little patience too okay. Here we go. There are three things that an engine needs to start, Fuel, spark (delivered at the proper time), and compression. An engine has no choice but to start when these three things are present. So let's start with spark. Please go to this link:.
Please go through the guide and get back to us with what you find out please. We will continue on from there.
Thanks,
Alex
2CarPros
Apr 14, 2019 at 10:52 AM
WILLING1995
My car does not have coils, just distributor, plug wires and plugs, anything i need to check other than condition of the plugs and verify that the wires are sparking?
Apr 14, 2019 at 11:14 PM
SCGRANTURISMO
  • 4,897 POSTS
Hello again,
If your spark plugs are producing a nice blue spark, then they should be okay. Here's how to test with your vehicle's ignition system, it is very similar to my vehicle's. First unplug the fuel pump relay from the Engine Compartment Fuse Block Relay #18. This will prevent the car from starting. It is also nice to have an extra spark plug you can replace the one you are testing to keep from blowing compression out of the hole, but not necessary. Okay, starting with number #1 spark plug, remove and run a wire from around where the socket fits onto the spark plug to the negative battery terminal of your battery. Attach it to the spark plug with a hose clamp.Set it on a board or non conductive surface. Have an assistant crank the engine. You want to see a nice blue arc from the spark plug. Repeat for all cylinders and get in contact with us with what you are able to be find out, please.
Thanks,
Alex
2CarPros
Apr 15, 2019 at 6:49 AM
