Dealer just replaced battery and all new cables less than two months ago, after leaving battery disconnected over night it cranks sometime. Drove it down the road and now I get the same problem. Electric locks don't work, windows don't work. Then I can go back to it and everything works.
Sunday, June 30th, 2019 AT 8:40 AM
MECHANIC
You need to check the voltages as I suggested.
Sounds like a low battery or bad connection.
Sunday, June 30th, 2019 AT 8:42 AM
HBUTLER56
MEMBER
I have checked voltage and and pulled and cleaned all cables, same thing dealer told me, when they told me it was battery and cables, and $1,200.00 later I am back with same problem.
Sunday, June 30th, 2019 AT 8:45 AM
HBUTLER56
MEMBER
Thanks for the help.
SPONSORED LINKS
MECHANIC
You are welcome.
What is the voltage at the battery while resting?
What is the voltage when the key is in the start position?
Sunday, June 30th, 2019 AT 8:48 AM
HBUTLER56
MEMBER
12.15 just battery
11.75 with key on
14 with it running
Sunday, June 30th, 2019 AT 12:25 PM
HBUTLER56
MEMBER
Seems like after it gets warm is when the problems start.
Sunday, June 30th, 2019 AT 12:27 PM
MECHANIC
Battery very low. Should be 12.6.
At 12 1 you have less than 25 percent of the battery charge working.
HBUTLER56
MEMBER
Then I suppose I need to take It back to the dealer, because they just put the battery in about two months back.
Monday, July 1st, 2019 AT 5:09 AM
HBUTLER56
MEMBER
The battery does not seem week, be cause when it will spend over it fires right up. You can wait a while and it fires right up, but once the truck warms up it may or may not turn over and when it wont turn over. All the lights light up on dash and I get all these warning messages. Not sure of that helps.
Monday, July 1st, 2019 AT 5:12 AM
MECHANIC
Again, 12.1 volts is very low. It is very weak.
You need to charge to 12.6 volts and then try it again.
