Will not start, says the MAF is bad?
143,000 MILES • 3.5L • V6 • 2WD • AUTOMATIC
CHARLESCHEESE
Says the MAF is bad, it all started with changing the radiator because it kept overheating and put a new thermostat in and a new starter in. And cleaned the fuel regulator pressure regulator. Found that the two throttle cables one to the cruise control and one choose a throttle body they were not working at the same time so a zip tied those together for a few days I was able to pump and pump and pump and get this thing to start but it would take a good 10 or 15 minutes to get the starter to catch the motor enough to start it any suggestions on what else i should do.
Jul 5, 2025 at 6:27 PM
MECHTRIX
  • 571 POSTS
Yep, I'm assuming you're using a scanner and if it's saying the MAF sensor is bad I'd change the MAF sensor. A bad MAF sensor can make it hard to start or not start at all and other things. They're pretty cheap and at least it's a step in the right direction. it seems like you're on the right track towards putting everything back to the stock configuration as you get closer to that." It should run better and better. good luck
Jul 6, 2025 at 5:10 AM
CHARLESCHEESE
I do appreciate that it's 50 miles to the nearest auto parts place for me I live pretty rural this was my only vehicle that was running up until today I did get another vehicle running I don't know anyone where I live out here it's all acreage and everyone keeps to themselves. So everything I've had to do I've had to do from scratch fabricate or figure it out on my own I did find that my fuels running fine through the fuel rail and then I did also find that the throttle cable and the cruise control cable were not moving simultaneously when you hit the gas pedal so I'm thinking at this point I can get it to start the head gasket might be shot that's one issue also I'm sure the MAF is toast I don't have any sensors someone stole that when the van was broke down on the side of the road but that was the first indicator for me that something was up I had sprayed starting fluid on it by accident instead of spring starting fluid behind it and she's the next tube going into the throttle body so I'll see what happens with it I'm pretty sure it needs that maf changed for sure and the gas pedal issue I've resolved with a zip tie for the time being till I can figure out how to adjust it.
Jul 7, 2025 at 8:55 AM
CHARLESCHEESE
I was able to force it to start yesterday with a pair of vice grips on both of the throttle cables and when I jump it take out the starter relay I can jump it with a wire and get it to start but I can't get it to start via the ignition even though I have switched relays to test it for whatever reason I don't think from the ignition to the starter solenoid it's getting as much power as if I jump it at the fuse box.
Also, when I take the starter relay out, I can hear the fuel pump running whereas when it's in I can't hear the fuel pump so it's kind of a strange thing, but I appreciate your help.
Jul 7, 2025 at 8:56 AM
MECHTRIX
  • 571 POSTS
The maf sensor will change some of that ..should start on its own dont know how well it will run after you change it but it should start a bit easier evan if the head hasket is blown at least we know the maf is bad so yep id probably just get another one ..sometimes you can clean them but sounds to me like this ones to far gone already probably best to just change it ..
Jul 7, 2025 at 11:40 AM
MECHTRIX
  • 571 POSTS
If it had been overheating for a while there is a chance the head gasket could be leaking id say do a compression test ..or a leakdown test to find out .. maybe before you sink any money into it
Jul 7, 2025 at 11:46 AM
MECHTRIX
  • 571 POSTS
Yeah didnt know about the fuel pump thing that is strange..how long has all this been going on ? ..
Jul 7, 2025 at 11:55 AM
MECHTRIX
  • 571 POSTS
Did you change the start relay already if not you might need that too.
Jul 7, 2025 at 12:06 PM
